Can the cores be assigned using command line to run?
Many .inp files are needed to run, so the batch process is expected, but Can the cores be assigned when using command line to run?
Use the tsp (task spooler) program available in linux.
Configure the slots (=number of cores) and submit all runs using tsp
@vasilis , thank you, i will try!
