Error with DISCARD card
Dear Vasilis,
thank you for your answer and your detailed questions.
Concerning the DISCARD card: I am really happy that the issue has been fixed. Yes, of course I am interested to test the fix prior to release.
Concerning the PARTH-THR card: If I correctly understood, the protons that are generated with an energy lower than the threshold are not killed and continue to be transported. Right?
Regarding your questions:
The reasons because I want to kill protons and deuterons from my simulation is explained here:
https://fluka-forum.web.cern.ch/t/difference-scoring-in-air-activation-between-fluka-and-mcnp/6341
As you can read, I am comparing the results between FLUKA and MCNP in the air activation (“INPU” and “INSHIEL” regions) by a D-T neutrons source. In MCNP I only considered the main neutron reactions because I thought they are most relevant. However, I found an important discrepancy in N-13 production and I suspect that the secondary protons can contribute. So, the simple way to check was to exclude protons and other particles from my FLUKA simulation. Actually, from the first results using PART-THR card, the value of N-13 is very close with that of MCNP. So it seems that I have solved my problem.
Regarding your other remarks:
The reason I changed some predefined material in FLUKA was to make equal the materials composition of FLUKA with MCNP ones.
  1. Thank you for your suggestion, I will use the predefined AIR material. I incorrectly thought that the predefined AIR material was different from ICRU definition.
  2. I defined user material in FLUKA for air, polyethylene, borated polyethylene and concrete according to the follow compendium:
    https://www.pnnl.gov/main/publications/external/technical_reports/PNNL-15870Rev1.pdf
    because they are the standard ones used in MCNP.
    I was aware that I didn’t consider the natural isotopic composition of some elements (for example, in polyethylene only H-1 is considered for hydrogen while natural composition is considered for carbon). In any case, to perfect my simulations I can include all natural composition of the elements, as you suggest.
    I considered also the problem of TSL libraries and the binding effects of hydrogen in water and I decided to not activate them both in FLUKA and MCNP. The water is part of the secondary shielding (labyrinth wall) and concrete wall: I guess that these material don’t contribute so much in air activation inside the labyrinth. Do you suggest to activate them at least for polyethylene and graphite?
Corrado
