Dear Fluka experts
I was trying angle of gantry. I need rotate different angle. first inp work correctly. but other inp give me error.Could you give me advice or example?
gantry.flair (3.9 KB) gantry.inp (2.2 KB)
Your input file cannot run because it is not currently possible with FLUKA to score DOSEQLET with a USRYIELD card. Try to score another particle by changing the “Part.” option of your “let2” detector (in Flair) or the WHAT(2) of the first card directly in the input file.
I suggest you check the .err files that are generated when you run FLUKA. These could be insightful to determine the issue.
thank you, I ''ll try it
