Dear All, @vasilis
In my institutional HPC cluster, I am trying to install flair3 (without root access) using source files.
The flair manged to install correctly.
The Geoviewer gives me error as follows with the make command.
lto1: fatal error: bytecode stream in file '/blues/gpfs/home/software/anaconda3/2019.7/lib/python3.7/config-3 .7m-x86_64-linux-gnu/libpython3.7m.a' generated with LTO version 6.0 instead of the expected 8.1
compilation terminated.
lto-wrapper: fatal error: c++ returned 1 exit status
/usr/bin/ld: error: lto-wrapper failed
make: *** [geoviewer.so] Error 1
The compilers were
python : Python 3.7.3 (default, Mar 27 2019, 22:11:17)
gcc -version: gcc (GCC) 9.2.0
make -version: GNU Make 3.82
I tried a newer version of python (Python 3.7.4) as suggested by my system administrator and ended up in the same spot.
lto1: fatal error: bytecode stream in file '/blues/gpfs/home/software/anaconda3/2019.10/lib/python3.7/config-3.7m-x86_64-linux-gnu/libpython3.7m.a' generated with LTO version 6.0 instead of the expected 8.1
Is there a way to get this compiled in the cluster?
Thanks
Sunil
