I am trying to model the response of a scintillator using the OPT-PROD and OPT-PROP cards. The input file I have works on the older version of fluka (2020.0) however when I try to run it on fluka_4.0.0 using the latest flair version and gfortran 10, I get the following error:
<< At line 4 of file cascade/mgcsnr.f
Fortran runtime error: Actual string length is shorter than the declared one for dummy argument ‘chmsg2’ (4/8) >>
Would anyone happen to know why this error message occurs on the newer version of fluka but not the older? I’ve also attached my flair file and log file if that helps.
Thanks and best regards,
Kyle
LUXE_Spectroscopy_W10.flair (10.9 KB)
LUXE_Spectroscopy_W10001.log (738 Bytes)
