Dear all
I would like to find out SPECSOUR card clearly, which may be a little vague for me in manual.
Could you help me with any one of the following, please?
How does the spectral index for sampling work? why set 1.75 is approprite?
I see the real specrum index is 2.75. (SPECSOUR/GCR-ION WHAT(5)) -
Does the transition energy for sampling has recommended value ? What should I set it according to? (SPECSOUR/GCR-ION WHAT(6))
What’s the number of the energy point in the spectra refer to? If I increase it value, what benefit will happen?(SPECSOUR/GCR-ION WHAT(9))
What’s the meaning of the possibilities used for the various ions? (SPECSOUR/GCR-ION WHAT(11))
If I use zzphi0465.spc of 28 files totally and set 5000 primary/cycle, how does the sample work among the different ions? Is the component percent of sampling results same as the real CR? set WHAT(11) or not, which is more reasonable? -
In SPECSOUR/GCR-ION, when and why choose the WHAT(12)< 0, i.e.make the ions are split instead of treating them as real one?
In additon, what’s the meaningful of the ALL-Nucleon spectrum existing ? I’m not sure what it’s advantage is and when I need to use. -
General question: what’s the difference of benefit of increasing the number of primary/cycle and cycles?
Just list my confusions here, please take it easy.
even one of them being answered would help me a lot.
Thank you and best
Yi
