Illegal instruction Error on macOS Sequoia
Dear @Obada ,
We’ve identified that this issue is related to the new linker introduced in the latest CLT.
To get FLUKA running again, please try the following temporary fix:
  • Open the FLUKA makefile, which you can find in the src directory of your FLUKA installation (<path to FLUKA>/src/makefile)
  • Add -ld_classic option to the linker rules for the FLUKA executables. You’ll need to add it in two places:
    • At line 43:
    ${FC} -ld_classic -o $@ ${LFLAGS} -L${LIBPATH} ${LIB}
    • and similarly at line 49:
    ${FC} -ld_classic -o $@ ${LFLAGS} ${INTOBJS} -L${LIBPATH} ${LIBRQMD} ${LIB} ${LIBDPM}
  • In the directory src, issue the commands make clean and make.
This workaround should allow you to run FLUKA in the meantime.
Please note that this is not a permanent solution, as -ld_classic is deprecated. We are working on a proper fix to ensure long-term compatibility with the CLT linker.
Please let us know if this works for you or if you have any further questions.
Best, Luigi
