Inquiry About Proper Scorer Setup for Energy Deposition in SiC Region
Fluka:4-5.1 Flair:3.4-3
FLUKA:4-5.1
Flair:3.4-3
I am currently simulating a semiconductor detector under neutron irradiation. I would like to find a suitable scor that can calculate the energy deposited by charged particles in the SiC region for a single neutron incidence, and then perform energy binning over multiple incident events.
I have tried using USRBDX and USRBIN, but USRBDX seems to only provide statistics on a specific surface, and I have not been able to configure USRBIN correctly.
Could you please advise which scorer I should use and how to properly configure it?
Thank you very much for your time and help.
wch
Dear yuyu li,
depend on your exact case, I would suggest you 2 approaches.
1 - I if you need just energy deposition scoring per particle. There is specific Fluka instrument created exectly for this use case - DETECT card. Which scores energy deposition per event
https://indico.cern.ch/event/656336/contributions/2729627/attachments/1552510/2439699/Scoring.pdf, page 4,
and also forum thread How to use the DETECT card
2 If you want to proceed to scoring several parameters, e.g. deposited charge of secondary electrons, I use a trick of running arrays of USRBDX and USRBIN detectors with an exaggerated number of runs, and then processing result with an external script.
Illia
