Source routine - Error: Can’t open included file ‘(DBLPRC)’
BiasingTest.f (9.1 KB) BiasingTest.inp (6.4 KB)
I am trying to score Dose Eq at the surface of the lead shielding.
  1. My results are zero when I take a single Co-60 source at (9.8,0,0) even after applying biasing. If I give more runs then I get an answer but the error is 100%. Why is it so?
  2. When I take multiple sources using source.f file, the source file is not compiled. The following error occurs:
    Started 2020.10.13 16:24:39
- Compiling: /usr/local/fluka/bin/fff htc2.f
gfortran -c -I/usr/local/fluka/include -g -O3 -fd-lines-as-comments -Wall -Waggregate-return -Wcast-align -Wline-truncation -Wno-conversion -Wno-integer-division -Wno-tabs -Wno-unused-dummy-argument -Wno-unused-function -Wno-unused-parameter -Wno-unused-variable -Wsystem-headers -Wuninitialized -Wunused-label -mtune=generic -msse2 -mfpmath=sse -fPIC -fexpensive-optimizations -funroll-loops -fstrength-reduce -fno-automatic -finit-local-zero -ffixed-line-length-132 -fbackslash -funderscoring -frecord-marker=4 -falign-commons -fbacktrace -frange-check -fbounds-check -fdump-core -ftrapping-math -ffpe-trap=invalid,zero,overflow -o htc2.o htc2.f
htc2.f:8: Error: Can’t open included file ‘(DBLPRC)’
Ended: 2020.10.13 16:24:39
Error compiling
Error: compiling file: htc2.f
No object generated
Kindly guide.
With regards,
Jyoti
Dear Jyoti,
Use the fluka_src_converter.py tool, see the post below:
Cesc
3 posts were split to a new topic: Zero result after biasing
