I want to obtain initial positions of optical photons produced in a material. I am using the following algorithm in the mgdraw.f :
ENTRY USDRAW ( ICODE, MREG, XSCO, YSCO, ZSCO )
IF ( .NOT. LFCOPE ) THEN
LFCOPE = .TRUE.
OPEN ( UNIT = 88, FILE = "result", FORM = 'FORMATTED',
& STATUS = "UNKNOWN")
END IF
CALL GEOR2N ( MREG, NAMREG, IERR )
IF(NAMREG .EQ. "TARGET") THEN
IF(JTRACK .EQ. -1) THEN
WRITE(88,'(1P,8G15.7)') XSCO, YSCO, ZSCO
Lpkill = .TRUE.
END IF
END IF
RETURN
I can see optical photons in the target region with usrbin, but myfile is empty. Moreover, I can obtain data when I change JTRACK=3 (electron, my beam particle). What is the problem or what could it be?
Also, is there a better way to obtain the initial position rather than saving the track position and then killing the track?
Selman
