Dear colleagues,
I ran into problems when try to plot using flair. I was following the instructions on the flair.cern website. Yet when I hit plot, an error message would pop-up. The attached is the screenshot.
Please let me know if you need any extra info to determine what is the problem.
Thank you in advance for your help.
Martin
Hi Martin,
the issue is, that you specified the Geometry position at z = -15, but at that position, there is no geometry to plot.
You need to change the position, or select -No- for geometry plotting, as the error message suggests.
Cheers, David
Hi David,
Thank you for enlighten me. The problem is resolved.
