Hi there,
I am in the process of using USRBDX to score neutrons produced from a target which is impinged by a low energy proton beam.
I had a couple questions:
1.) Regarding converting sum.lis output files from USRBDX runs to ASCII format: I tried to convert the desired sum.lis files to ASCII format using Flair, but the file which Flair produced was empty. Can someone help me understand why this is happening?
2.) Also, is there a trivial way to integrate the neutron flux over the entire energy range of neutrons which are produced from the target, using the Flair interface?
3.) In the sum.lis file, what is the difference between Flux and Cumulative Flux?
Thanks for your help.
Dalini
