Dear Regan,
- There is two issues with the annular sampling:
- There is a bug, which requires setting the
xandycoordinates in the source routine as well. - You need to use the double precision notation (like
5.0D0) when you set the minimum and maximum radius of the sampling.
There is no need to manually normalize the probabilities, it is done automatically.
Currently only one histogram can be specified. If you want to sample from more than one, you need to duplicate the the function using a different name.
You probably want to look at the spectrum sampling routine posted here: Questions about source_newgen.f - #8 by mayank.rse This may be more suitable for sampling angles.
