Dear All,
When I utilize AUXSCORE with What(1) set to RESNUCLE, an error message is triggered:
*** Unable to resolve name element RESNUCLE in card ***
AUXSCORE RESNUCLE RES_1h RES_3y
*** run stopped ***
I would greatly appreciate it if someone could assist me with this.
The input file is below.
Thank you.
Andrei
TITLE
*Set the defaults for precision simulations
DEFAULTS PRECISIO
PHOTONUC 1. HYDROGEN @LASTMAT
LAM-BIAS 0.0 0.01 PHOTON
* Define the beam characteristics
BEAM -0.04 -0.1 -0.1 ELECTRON
* Define the beam position
BEAMPOS 0.0 0.0 -1.
GEOBEGIN COMBNAME
0 0
*Black body
SPH blkbody 0.0 0.0 0.0 100000.0
*Void sphere
SPH void 0.0 0.0 0.0 10000.0
*Cylindrical target
RCC target 0.0 0.0 0.0 0.0 0.0 4.5 1.5
RCC reflect 0.0 0.0 0.0 0.0 0.0 8.5 5.5
END
*Black hole
BLKBODY 5 +blkbody -void
*Void around
VOID 5 +void -reflect
*Target
TARGET 5 +target
REFLECT 5 +reflect -target
END
GEOEND
*..+....1....+....2....+....3....+....4....+....5....+....6....+....7..
MATERIAL 92. 235. 18.95 235.U235
MATERIAL 92. 238. 18.95 238.U238
LOW-MAT U235 92. 235. 296. 235-U
LOW-MAT U238 92. 238. 296. 238-U
MATERIAL 92. 18.95 URANIUM
COMPOUND -0.2 U235 -0.8 U238 URANIUM
ASSIGNMA BLCKHOLE BLKBODY
ASSIGNMA VACUUM VOID
ASSIGNMA URANIUM TARGET
ASSIGNMA LEAD REFLECT
RADDECAY 1. 1. 3. 100001.
* 30 days irradiation, at 25kW, 40MeV
IRRPROFI 2592000. 3.900E+15
* cooling times:
* 1h 2h 5h 12h 1d 2d
DCYTIMES 3600 7200 18000 43200 86400 172800
* 3d 1w 2w 3w 1m 2m
DCYTIMES 259200 604800 1209600 1814400 2592000 5184000
* 3m 4m 6m 1y 2y
DCYTIMES 7776000 10368000 15552000 31104000 62208000 93312000
DCYSCORE 1 RES_1h RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_1h
DCYSCORE 2 RES_2h RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_2h
DCYSCORE 3 RES_5h RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_5h
DCYSCORE 4 RES_12h RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_12h
DCYSCORE 5 RES_1d RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_1d
DCYSCORE 6 RES_2d RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_2d
DCYSCORE 7 RES_3d RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_3d
DCYSCORE 8 RES_1w RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_1w
DCYSCORE 9 RES_2w RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_2w
DCYSCORE 10 RES_3w RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_3w
DCYSCORE 11 RES_1m RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_1m
DCYSCORE 12 RES_2m RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_2m
DCYSCORE 13 RES_3m RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_3m
DCYSCORE 14 RES_4m RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_4m
DCYSCORE 15 RES_6m RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_6m
DCYSCORE 16 RES_1y RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_1y
DCYSCORE 17 RES_2y RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_2y
DCYSCORE 18 RES_3y RESNUCLE
RESNUCLE 3 -21 TARGET 1.RES_3y
* Thresholds: 3MeV thresholds
EMF
EMFCUT -0.003 0.003 BLKBODY @LASTREG
EMFCUT -0.003 0.003 0.003 HELIUM @LASTMAT PROD-CUT
DELTARAY 3.0E-3 VACUUM @LASTMAT
* Physics
PHYSICS 3. 0.0 0.0 0.0 0.0 0.0EVAPORAT
PHYSICS 1. COALESCE
*Set the random number seed
RANDOMIZ 1.0
*Set the number of primary histories to be simulated in the run
START 1000000
STOP
