Hi. I’ve installed fluka and flair latest versions. When I’m running next Photoyields.inp (13.0 KB) .inp file in status it shows that Finished with ERRORS. What’s the problem ?
Hi, I ran the input you uploaded above for a total of a few hundred thousand events and did not meet any issue.
Which versions are you exactly using?
Please have a look at the content of the .out, .log and .err files of the failing run, possibly inside a left temporary directory such as fluka_#.
Note also that, with a 17.5 MeV proton beam, all the PHOTONUC and LAM-BIAS cards (applying to electrons, positrons and photons) are totally irrelevant and fill the input file pointlessly, as well as the RADDECAY card, which is oddly asking for semi-analogue isotope decay and you do not use.
