deo input.pdf (17.5 KB)
I want to calculate the lateral and deep dose deposition. With the same input, I also like to calculate the linear energy transfer.
As well as the dose due to the secondary neutron generated by the primary beam.
Please upload your input file as *.inp, and not as pdf.
From what I see so far, you have defined correctly the two dose deposition USRBINs. To compute the LET, please have a look at this presentation, in particular slide 22. Here, you have an example of the USRYIELD cards to score Particle LETs.
Let me know if there is anything I can be helpful with.
