Dear Flair Creators:
My flair update to 3.0-6 by using repository and test DICOM again.
The VOXEL seems good but STOP NO NR_TH VOXEL FOUND
Here is the voxel
Thanks
Yuni
Thanks
Yuni
the error points that there was a region defined in the header of the voxel, but there was no corresponding region in the voxel data.
It seems that it is a cropped region and not the entire CT.
Could you try with th entire CT without cropping?
it would be nice if it is possible that you provide us with the voxel and/or dicom that produce, so we can debug it.
Vasilis
Dear Vasilis:
It’s work without cropping.
Thanks.
Yuni
Dear Dr. Vasilis:
Here generate some more problems about DICOM module:
3.It seems the lateset version flair 3.0-6 has some problem in displaying the image, nothing in Slice and RTViewer for a lot cases.
Regards
Yuni
Hi @YuniWang2020,
We are currently testing and upgrading the DICOM modules.
We shall have it ready within the end of February, with the mentioned features mentioned above.
Wioletta
Dear Wioletta and Flair Creators:
Thanks for the reply. and My Flair update to 3.0-7,
VOXEL can be generated but can not display in Geometry.
I test wo set CT images, one display no image in Slice and RTviewer, another display no image in RTviewer. some feed back in terminal I paste here:
and how to get planned dose?
is it generated by USRBIN?
The Best
Yuni
Hi Yuni,
thank you for the bug report. We are currently working on that and in the next days we will have the corrected version of flair and fluka that will address all that.
Vasilis
Great! Hope to use this powerfull MC QA tool as the paper described in our PT center in the near future.
Yuni
