I run FLUKA in a cluster utilizing a few hundred cores. In one particular run, I got a few crashes that I could not understand the reason for. Looking at one temporary directory, I can see the following files (I replaced the filename part of it with *).
drwxrwx---+ 2 sunil cels 16384 May 10 13:32 .
drwxrwx---+ 34 sunil cels 1048576 May 10 13:05 ..
-rw-rw----+ 1 sunil cels 46 May 9 21:39 *_171001.log
-rw-rw----+ 1 sunil cels 15873 May 9 21:39 *_171.inp
-rw-rw----+ 1 sunil cels 82 May 9 21:39 *_68001.err
-rw-rw----+ 1 sunil cels 622 May 9 21:39 *_68001.log
-rw-rw----+ 1 sunil cels 65534 May 9 21:39 *_68001.out
-rw-rw----+ 1 sunil cels 15873 May 9 21:39 *_68.inp
-rw-rw----+ 1 sunil cels 0 May 9 21:39 core
-rw-rw----+ 1 sunil cels 0 May 9 21:39 fort.1
lrwxrwxrwx 1 sunil cels 40 May 9 21:39 fort.11 ->*_68001.out
lrwxrwxrwx 1 sunil cels 40 May 9 21:39 fort.15 -> *_68001.err
-rw-rw----+ 1 sunil cels 42563 May 9 21:39 fort.16
lrwxrwxrwx 1 sunil cels 40 May 9 21:39 fort.2 -> *_171002
-rw-rw----+ 1 sunil cels 0 May 9 21:39 .timer.out
I see two input files (!) the 68th and 171th spawns and two log files pertaining to the these. They both have the same error message.
At line 31 of file main/flabrt.f (unit = 15)
Fortran runtime error: Cannot open file 'fort.15': Too many levels of symbolic links
Error termination. Backtrace:
#0 0x2b301beb23fa in data_transfer_init
at /blues/gpfs/software/centos7/spack-latest/var/spack/stage/gcc-9.2.0-pkmzcztqna4f2m7hxvqjrrrzpqyclnt3/gcc-9.2.0/libgfortran/io/transfer.c:2869
#1 0x54231f in flabrt_
at main/flabrt.f:31
#2 0x490276 in fl64rd_
at rnd/flrm64.f:210
#3 0x593b51 in rnread_
at rnd/rnread.f:26
#4 0x404711 in flukam_
at main/flukam.f:1565
#5 0x402f50 in fluka
at main/fluka.f:77
#6 0x402f50 in main
at /shared/src/usflmd.inc:15
The out file has this message at the end.
***** Next control card ***** RANDOMIZ 1.000 171.0 0.000 0.000 0.000 0.000
**** No Random file available !!!!!! ****
Abort called from FLRM64 reason NO RANDOM FILE Run stopped!
STOP NO RANDOM FILE
These happened with about 10 runs out of 180. I thought FLUKA writes to a temporary folder with _00 suffix in the name if there exists a folder with the name that it was about to write to, to prevent two input files ending up in the same temporary directory. Is that what was happening here, or is it something else?
Many thanks for all your help.
Sunil
I see that you submitted a run using the rfluka and a filename containing the star “*” character, which creates a link to a file pattern *_68001.err instead of a input_68001.err leading to a crash
There is no * in the input file name. Sorry for the confusion by introducing it, which was meant as a wildcard to show the long filename that I removed before posting here. Here is what is inside the temporary folder for another crash.
(base) [sunil@beboplogin2 fluka_31659]$ ls -al
total 741
drwxrwx---+ 2 sunil cels 16384 May 11 12:09 .
drwxrwx---+ 3 sunil cels 262144 May 11 19:35 ..
-rw-rw----+ 1 sunil cels 622 May 11 12:09 11V_Li_stand_plugged_176001.log
-rw-rw----+ 1 sunil cels 17688 May 11 12:09 11V_Li_stand_plugged_176.inp
-rw-rw----+ 1 sunil cels 622 May 11 12:09 11V_Li_stand_plugged_69001.log
-rw-rw----+ 1 sunil cels 74014 May 11 12:09 11V_Li_stand_plugged_69001.out
-rw-rw----+ 1 sunil cels 17688 May 11 12:09 11V_Li_stand_plugged_69.inp
-rw-rw----+ 1 sunil cels 0 May 11 12:09 core
lrwxrwxrwx 1 sunil cels 77 May 11 12:09 fort.1 -> /lcrc/project/RadPhyRP/ATLAS/nuCAR/11VnuCARIBU/ran11V_Li_stand_plugged_176001
lrwxrwxrwx 1 sunil cels 30 May 11 12:09 fort.11 -> 11V_Li_stand_plugged_69001.out
lrwxrwxrwx 1 sunil cels 30 May 11 12:09 fort.15 -> 11V_Li_stand_plugged_69001.err
-rw-rw----+ 1 sunil cels 48586 May 11 12:09 fort.16
lrwxrwxrwx 1 sunil cels 30 May 11 12:09 fort.2 -> ran11V_Li_stand_plugged_176002
-rw-rw----+ 1 sunil cels 0 May 11 12:09 .timer.out
This is also strange, I see 2 .inp and .log files inside without any .err. Normally rfluka should copy only the master input.
Could it be that due to many multiple runs you have some that run on the same temporary fluka_XXX folder?
Vasilis,
Yes, I agree, its strange and that is what is perplexing to me.
It appears that is what is happening here unless the cluster/slurm is doing something. But isn’t that scenario supposed to not happen, because FLUKA renames a target folder with a suffix “_00” or something like that when there exists a folder with the intended folder number/name ? I have seen FLUKA doing that as well.
Normally it should check for _00, _01, … until it finds an non existing directory, and it should abord if there are 100dirs with the same name
The check is done in rfluka lines 232-249,
Ηowever there is no semaphore locking, so we might have a race condition
