I am new to Fluka, i have installed fluka and flair in ubuntu.i ran exxample file through terminal and it work. I try to open flair to ran example too but when flair open, a message always pop up that (Error fluka executable not found: can not FLUKA excutable “fluka” please set the correct FLUKA directory in preference).My Fluka directory is home/username/FLUKA2011.2x.8 and my environment was set as export FLUPRO=/home/username/FLUKA2011.2x.8 and export FLUFOR=gfortran. My flair preference show Fluka directory as home/username/FLUKA2011.2x.8 and program as home/username/FLUKA2011.2x.8.
I used the following command to run from terminal and it work.
@horvathd
how do i update my Fluka to 3.0, i my flair is 3.0-2 version but my fluka show unknown version. I do i unstall the previous installation and install FLUKA 3.0. i am new to both ubuntu linux and FLUKA.
yes, it it the best to remove the other version of FLUKA, and download FLUKA 2011-3.0 from fluka.cern. You can find the guide for the installation here.
Thank you for response
What is the command to uninstall other version of fluka, i am using ubuntu linux and which version of fluka do you suggest i should install.
@ytaiwo85 it depends how you installed it.
If you installed it manually from the tar.gz then a simple rm -Rf $FLUPRO
will be enough.
If you installed it with the package like .rpm you can use
the rpm -e fluka2011
