I m trying to calculate radiation dose rate caused by a Mo100 target activated by 22MeV proton, the problem is how to use BIN-SOUR card. I have looked through the discussion about the BIN-SOUR, but I still have some questions. How to set BEAM card, I want to calculate the dose of all the isotopes produced, so the particle type is not single (includes neutron/photon).
Also, I would like to know the BEAMPOS card setting for sure, if I input the coordinate, fluka would put the sou-bin centered the coordinate, right? And the direction of the BIN-SOUR, how to set to isotropic.
Here are the input files I USE.BIN-SOUR is used to calculate the BIN source. Open is used to calculate the radiation dose rate.
Looking forward to your kind help!
Cheers!
BIN-SOUR.flair (20.6 KB)
BIN-SOUR.inp (8.1 KB)
OPEN.flair (19.7 KB)
OPEN.inp (5.2 KB)
Dear Sean,
Many thanks for your question.
With FLUKA there is typically no need to run a two-step simulation to estimate residual dose rates and residual activity: you can add a DOSE-EQ scoring (+DCYSCORE) in the input file.
You can have a look at the FLUKA manual or at the FLUKA lectures on activation.
Just a few comments on your input file. You don’t really need MUPHOTON for 22 MeV protons. On the contrary, COALESCENCE must be activated for reliable results.
Davide
