Recently I am using USRYIELD for the scoring of photon fluence from electron on a solid target. I take the first quantity for particle energy and the second for polar angle. I made a check with three USRYIELD detectors with polar angle from 0-60, 0-30, 30-60 respectively. As the results from the three are similar, i.e. the first one dose not equal to the sum of the rest two. So I think as prescribed in the Note5 in the manual of USRYIELD, the result also get averaged over the second quantity. If so, the results should be in per polar angle, in per degree or per rad?
Xiao
