I am simulating a stacked foil geometry composed of alternating titanium (Ti) and zirconium (Zr) layers:
Ti – Zr – Ti – Zr – Ti – Zr – Ti – Zr
Each foil is 10 µm thick.
The stack is irradiated by an alpha beam with:
Energy: 17.5 MeV
Beam profile: rectangular, 1 cm × 1 cm
My objective is to calculate the induced activation in each individual foil.
However, the results appear questionable. In particular, for the Zr foils, I observe significant production of vanadium (V) and chromium (Cr). This behavior seems unphysical.
I would appreciate advice on the following points:
Can a 10 µm layer thickness lead to geometrical or tracking limitations in FLUKA (e.g., boundary crossing accuracy)?
Are there recommended strategies for modeling very thin-layered targets (e.g., geometry definition, region splitting, lattice use)?
Should specific transport or production thresholds (e.g., cuts, delta-ray production, heavy fragment transport) be adjusted in this case?
Are there best practices for activation scoring (e.g., RESNUCLEi, DCYSCORE, IRRPROFI) in thin targets?
Unfortunately, increasing the foil thickness is not an option, as 10 µm reflects the experimental configuration.
Any guidance on obtaining accurate, reliable activation results in this setup would be greatly appreciated.
Rubi
FLUKA:
Flair:
