Dear Vasilis,
sorry to bother you again on the same topic. I tried to add three include instructions, as you suggested, to import a simple block of geometry inside another but there is some problem.
You find in attach all the files (.out added in order to upload).
This is the error message
Started 2020.01.16 16:40:12
e> ERROR: Region ‘vacuum’ What=-1 Type=expr: region expression: + intersection, - subtraction, | union, (…) parenthesis allowed
Invalid body ‘cont’
e> ERROR: Region ‘vacuum’ Region vacuum invalid token: cont
So the imported container can’t be subtracted from the main sphere because the cont body is not available. The first include instruction (#include prova2.bodies) is processed in a way don’t understand because I can’t see the included bodies in geometry editor neither in the input file. Moreover, in other attempts I see that Flair sometime actually rewrites the content of the included files, erasing their content or writing a minimal input file inside prova2.bodies. In the latter case closing and reopening Flair and prova1.flair, prova 2.bodies as an input file is incorporated in the main prova1.inp cutting out all remaining cards (other regions definition and assignment). I also noticed that often the instruction #include prova2.bodies is completed by Flair with a #endinclude instruction.
I tried to add #endinclude by hand in the main input for all the include files but with no results.
Could you please point out any mistake I made or provide a minimum working example?
Michele
prova.tar.xz.out (932 Bytes)
