Dear All,
I’m running the following test geometry scoring r-phi-z on FLUKA4-3.4
Although I have set phi limits, they are not displayed in the formatted .bnn file.
What is the reason for this? Am I doing something wrong?
Cheers, Peter
Input
TITLE
*Set the defaults for precision simulations
DEFAULTS PRECISIO
*Define the beam characteristics
BEAM 10.0 NEUTRON
USRBIN 11 PROTON -22 4 2.54 6philims
USRBIN 3 1.17 3 1 3 1 &
USRBIN 11 PROTON -22 4 6nolims
USRBIN 3 3 1 3 1 &
*Define the beam position
BEAMPOS
GEOBEGIN COMBNAME
0 0
*Black body
SPH blkbody 0.0 0.0 0.0 100000.0
*Void sphere
SPH void 0.0 0.0 0.0 10000.0
*Cylindrical target
RCC target 0.0 0.0 0.0 0.0 0.0 10.0 5.0
XYP split 7
END
*Black hole
BLKBODY 5 +blkbody -void
*Void around
VOID 5 +void -target
*Target
TARGET 5 +target +split
*Target
TARGET2 5 +target -split
END
GEOEND
*..+....1....+....2....+....3....+....4....+....5....+....6....+....7..
ASSIGNMA BLCKHOLE BLKBODY
ASSIGNMA VACUUM VOID
ASSIGNMA COPPER TARGET
ASSIGNMA GOLD TARGET2
*Set the random number seed
RANDOMIZ 1.0
*Set the number of primary histories to be simulated in the run
START
STOP
Content of formatted scoring file
1
R-Phi-Z binning n. 1 "philims " , generalized particle n. 1
R coordinate: from 3.0000E+00 to 4.0000E+00 cm, 1 bins ( 1.0000E+00 cm wide)
P coordinate: from -3.1416E+00 to 3.1416E+00 rad, 3 bins ( 2.0944E+00 rad wide)
Z coordinate: from 3.0000E+00 to 6.0000E+00 cm, 1 bins ( 3.0000E+00 cm wide)
Data follow in a matrix A(ir,ip,iz), format (1(5x,1p,10(1x,e11.4)))
accurate deposition along the tracks requested
this is a track-length binning
1.8755E-02 3.5164E-04 2.2910E-04
Percentage errors follow in a matrix A(ir,ip,iz), format (1(5x,1p,10(1x,e11.4)))
7.0286E+00 2.5520E+01 5.8769E+01
1
R-Phi-Z binning n. 2 "nolims " , generalized particle n. 1
1.8255E-03 1.1826E-03 9.2067E-04
1.9938E+01 1.5400E+01 3.3628E+01
