graham
(Graham Freestone)
1
FLUKA: 4.5.2
Flair: -
Operating system: Mac OS Tahoe 26
Compiler: gcc13
Hi Folks,
(complete newbie here).
I’m trying to install gcc (and the FLUKA / FLAIR) using Macports, and I’m getting this error:
Error: Cannot install gcc13 for the arch ‘arm64’ because
Error: its dependency libgcc13 is only installed for the arch ‘x86_64’
Error: and does not have a universal variant.
Error: Unable to execute port gcc13: architecture mismatch
So I’m guessing that it’s an intel vs apple silicon issue… Please Help!
kind regards
Graham
luillo
(Luigi Salvatore Esposito)
3
Hi @graham,
Could you please use a newer version of gfortran? I’m using gcc15 and it works on my Mac.
Please let us know if this helps.
graham
(Graham Freestone)
4
hi Luigi,
I tried Fortran v15, and (second time around), it gave me this error
sudo port install gcc15
- → Upgrading already installed dependencies of gcc15
Error: Cannot install libgcc for the archs ‘arm64 x86_64’ because
Error: its dependency libgcc15 does not build for the required archs by default
Error: Unable to execute port gcc15: upgrading deps for gcc15 failed
regards
Graham
luillo
5
Hi @graham,
It seems there’s a compatibility issue between the currently installed libgcc15 in your MacPorts environment and gcc15.
To resolve this, I suggest to
sudo port clean libgcc libgcc15 gcc15
Then try reinstalling gcc15. You might also need to clean any other ports showing a conflict so do that as well.
Cheers, Luigi
