Basic project - Finished with errors
hello fluka experts, am a very new user when I load any basic project without changing anything in the input file and go running a red message appears with me ( finished with errors ) after five seconds
Hello, could you check what messages you get in the output/log/error files? These you can check in the Run tab and selecting the “Files” output files inspection page.
Have you simply loaded the “basic” FLUKA input file or it is another input file? If yes please share it so we can have a look.
Andreas
am post my problem before that but no one answers me
can anyone help me?
I new user of fluka code I used the code in the treatment planning system
in the trying stage, I loaded the basic project without changing anything in the input file
but a red message appears with me ( finished with errors ) after five seconds
Please read the answer above
thanks alot for reply me
im reply you but there is a broplem in my email
my project file was basic fluka project.
test.flair (892 Bytes)
tutorial.inp (893 Bytes)
test.out (317 Bytes)
Dear @walaa.khalil88,
if you open the .out file you would see the following error message:
Error: Incompatible gfortran version!
   System gfortran version: 7
   FLUKA package version:   9
You need to install the FLUKA version which is compatible with your system. For more information see: Installation how-to | The official CERN FLUKA website
dear david thank you for your speedy reply
can you help me to solve this error.
my system is windows 10
I understand from your answer that I must install fluka package version 7 to be compatible with my system.
but I don’t know-how
Are you using WSL?
Did you install fluka starting from the .deb package or from the .tgz file?
Alternatively to installing another fluka version, you can install gfortran 9.
