Dear FLUKA experts:
Here is a question when I was using Source.newgen.f to define the direction distribution of the photon, I found there is no function to define the Beams’ direction distribution of sampling from histogram spectrum, how do I solve this problem?
Dear @22111140001,
First of all, let me apologize for the rather delayed answer.
Indeed, the user routine source_newgen.f does not have a dedicated function to define a beam direction distribution from sampling from a histogram. However, you can nevertheless use a work-around using the sample_histogram_momentum_energy function, e.g. as follows:
! Histogram file has to have 3 columns:
! - Emin (of the bin)
! - Emax (of the bin)
! - dN/dE (bin height; NOTE: doesn't need to be normalized)
direction_cosx = sample_histogram_momentum_energy('histogram.txt', "GeV")
direction_cosy = 0.2
direction_cosz = 0.
I recommend to activate the debugging flag (debug_logical_flag = .true.) which will print the source particle information in the log file, for example:
source_newgen.f - Debug output
Particle Mom. [GeV/c] X [cm] Y [cm] Z [cm] Cosx Cosy Cosz Weight
7 1.0000000E+01 0.0000000E+00 0.0000000E+00 0.0000000E+00 7.7268944E-01 6.3478424E-01 0.0000000E+00 1.0000000E+00
7 1.0000000E+01 0.0000000E+00 0.0000000E+00 0.0000000E+00 8.2323275E-01 5.6770400E-01 0.0000000E+00 1.0000000E+00
7 1.0000000E+01 0.0000000E+00 0.0000000E+00 0.0000000E+00 8.5146799E-01 5.2440659E-01 0.0000000E+00 1.0000000E+00
7 1.0000000E+01 0.0000000E+00 0.0000000E+00 0.0000000E+00 9.0702924E-01 4.2106764E-01 0.0000000E+00 1.0000000E+00
7 1.0000000E+01 0.0000000E+00 0.0000000E+00 0.0000000E+00 8.9768122E-01 4.4064547E-01 0.0000000E+00 1.0000000E+00
7 1.0000000E+01 0.0000000E+00 0.0000000E+00 0.0000000E+00 8.1779441E-01 5.7551046E-01 0.0000000E+00 1.0000000E+00
7 1.0000000E+01 0.0000000E+00 0.0000000E+00 0.0000000E+00 8.3873502E-01 5.4453978E-01 0.0000000E+00 1.0000000E+00
7 1.0000000E+01 0.0000000E+00 0.0000000E+00 0.0000000E+00 8.4157193E-01 5.4014505E-01 0.0000000E+00 1.0000000E+00
7 1.0000000E+01 0.0000000E+00 0.0000000E+00 0.0000000E+00 9.1174499E-01 4.1075672E-01 0.0000000E+00 1.0000000E+00
7 1.0000000E+01 0.0000000E+00 0.0000000E+00 0.0000000E+00 8.8365788E-01 4.6813326E-01 0.0000000E+00 1.0000000E+00
Please note:
i) Use “GeV” as units such that your values will not be rescaled.
ii) The cosines will be renormalized to 1 (pay attention to the direction_flag as well).
iii) There will also be a sampling within the bin itself (i.e. from the bin Emin to Emax).
iv) It should be pointed out that the ‘sample_histogram_momentum_energy()’ function can only sample from a positive energy range, any negative value is rejected.
Let me know if this helps and if I can be of further assistance.
Daniel
Dear Daniel Prelipcean
Thank you so much for your helpful reply, I have solved the problem, I really appreciate your kind help.
Best wishes,
liuyuCui
