BEAMAXES card is not taken into effect by FLUKA after using source_newgen.f. Is there any way to incorporate it manually into the source_negen.f as there is no option for that (only direction cosines are there)?
Thanks
ROHIT
Thanks
ROHIT
Dear Rohit,
you are correct the BEAMAXES card is not taken into account when using the source_newgen.f (or the old source.f) user routine.
You need to change the direction cosines of the particles manually, but it should be quite easy to program a subroutine which will do it for you.
