Hi dear colleagues,
I followed the instructions in “Installing FLUKA/Flair on Windows 10 using WSL” and got stuck at step 2.2. I could not find the path to FLUKA directory using ls command. In addition, according to the flair’s pop-up window, FLUKA is not installed.
The terminal has the following lines which could help you guys locate the problem.
root@DESKTOP-M0BBCNO:/mnt/c/Users/XX/Downloads# dpkg -i fluka-2011-3.0.Linux-gfor7_amd64.deb
(Reading database … 53042 files and directories currently installed.)
Preparing to unpack fluka-2011-3.0.Linux-gfor7_amd64.deb …
Unpacking fluka (2011-3.0) over (2011-3.0) …
Setting up fluka (2011-3.0) …
root@DESKTOP-M0BBCNO:~#
Thank you in advance.
Martin
