In a simulation using fluka, the EM energy was calculated in a cylinder volume,
the result was plotted in flair, here is the figure:
y axis represents the radius direction, only half figure was plotted,
but i want the total figure, it can be achieved in flair?
here is the .inp file:
MeshTally.inp (1.9 KB)
amario
(amario)
11 November 2022 05:29
2
Dear @Newconcept_1979 ,
You have defined a cylindrical R-Phi-Z scoring. A cylinder with a negative radius makes no physical sense, R is defined as positive quantity, therefore R=0 is the minimum value R can achieve.
horvathd
(Dávid Horváth)
11 November 2022 07:49
3
in addition to @amario ’s answer, if you plot the results using the Geometry editor / viewer, you can visualize both sides of the cylinder.
See:
vs.
