I am studying the medical application of Fluka. Fortunately, after studying some lectures, I successfully generated .vxl file and imported RTPLAN and RTDOSE in flair. But I encountered a problem when I tried to load RTstructure. As shown in the figure, I can’t find RTstructure, meanwhile, the other three were successfully loaded. I will upload all my files, please help me check the problem.
Its unclear for me why it didn’t show the RTSTRUCT. Permission problem?
When I opened your files in my computer they appeared correctly.
Please take this flair file, which is the one you send with the addition of the RTSTRUCT pointer inside
Hi @vasilis ,unfortunately, it still hasn’t been loaded after I updated the software and used your new files. I don’t know what permissions limit my to load RTSTRUCT. It should be loaded in Dateset, under normal circumstances, just as RTDOSE and RTPLAN, right?
Perhaps you have any other ideas I can try to solve the problem?
I haven’t solved the above problem yet.
1.If possible, I would like an example to test.
2.How should I define the structure now?
This is particularly important to me.
Hi, my flair version is 3.2.4, and I successfully loaded RTSTRUCTURE by a new CT, the difference between the two is shown in the following figure. I don’t know if this is the key to the problem, because the previous CT , RTDOSE and RTPLAN can be loaded normally, while RTSTRUCTURE cannot be loaded, but both of them have the same “Specific character set”.
