FLUKA: 4-4.1
Flair: 3.3-1
Operating system: macOS Tahoe, version 26.2Dear FLUKA experts,
I am studying the charging of a small object exposed to a proton beam. The geometry is a copper sphere with a radius of 50 µm. As a first approach, I used USRBDX to score electrons crossing from the material into vacuum, normalized by (1/4π) to account for solid angle.
However, I realized that not every escaping electron necessarily contributes −1e to the net charge of the object. For example, electrons produced in pair production or other processes may be accompanied by a corresponding positive charge (e.g. positrons or ions) that could also escape, partially compensating the charge balance. To investigate this, I implemented a USERDUMP with a custom mgdraw routine to record particles crossing into the VOID region. I also included evtflg.inc and attempted to tag the interaction type using flags such as LPAIRP, LBRMSP, LCMPTN, etc. In addition, I tried to access ISPUSR(1) (via STUPRE) to store the interaction type, but this quantity is always zero in my output.
Any guidance would be greatly appreciated.
Best regards,David
plot.pdf (56.1 KB)
mgdraw_test.f (2.5 KB)
cu50.inp (1.3 KB)
