I am running a FLUKA simulation to calculate PKA (Primary Knock-on Atoms), nuclear reaction channels, and gas production using the attached input files and FLAIR interface. After the simulation completed, I obtained several output files, but I need clarification on the following points:
Nuclear Reaction Channel Data Location
I see.logand.logfiles generated, but I am unsure which file contains the exact nuclear reaction channel data. Could you please confirm which output file(s) contain the detailed nuclear reaction channel information, and if there is a specific flag or card I need to activate to ensure this data is properly written? -
Empty
pka.datFile
Thepka.datfile is generated but remains empty (0 bytes). Is this expected, or does this indicate a problem with my setup? Are there specific settings (e.g.,USRYIELD,USERDUMP, orEVENTDAT) that must be configured correctly to populate this file? -
Gas Production Data Verification
I also have a file that appears to contain gas production data, but I am not entirely sure if this is the correct and complete dataset for gas production. Could you confirm which FLUKA output file is the definitive source for gas production results, and whether any additional processing or scoring is required?
I have attached the .inp, .flair, and relevant output files for your review. Any guidance on correctly extracting and interpreting these quantities would be greatly appreciated.
Thank you in advance for your help.
Input file
mgdraw_comprehensive.f (17.2 KB)
PWR.flair (7 KB)
PWR.inp (6.4 KB)
Source_NewGen_updated.f (18.9 KB)
PWR001.log (12.9 KB)
PWR001_reactions.log (490.0 KB)
PWR001_pka_spectrum.dat (62 Bytes)
PWR001_gas_production.dat (362.3 KB)
