Dear fluka experts,
When I use make command to install fluka doesn’t work : (Look at the picture )
thank you
Dear @youssef.allay,
Did you search on the forum for the same problem? You’ll find that the same question has already been asked and answered. You can even find it with google.
Dear @amario
I searched before asking, knowing that I worked with Fluka a lot without problems, now I am trying to install it again on another computer, I am facing this problem.
Have you tried the proposed solutions?
Do they fail?
How do they fail?
Do you get an error message?
I think the error i encountering during the make step is due to the linker not being able to find the libstdc++ library, which is part of the GNU Standard C++ Library. This often happens if the required development packages for C++ libraries are not installed on the system.
so i tried to solve the problem but the same error ( look at the screen )
Precisely. Since the problem is a missing package, install it on your machine. If you don’t have admin rights on that machine, then contact the system administrator.
I tried all the methods but the problem was not solved, so I put my question in the forum.
I’m sorry but your problem is not about FLUKA but about the installation, on the machine you’re using, of a package required to run FLUKA.
You have to ask the help of your system administrator.
