Hi. will use Fluka for Windows 11. I enabled the wsl and initialliated Ubuntu. However, at the step of 3 (Setting up for FLUKA and installing Flair), I downloaded the zip file containing the setup script to my c drive and I changed the directory where I downloaded the script, and run the command “sudo ./setup_wsl.sh” then I got error saying “sudo: ./setup_wsl.sh: command not found”. So I can’t go further.
Dear mgulmen,
Did you run the command in the Ubuntu terminal?
Yes. I run the sudo command in Ubuntu terminal.
Could you tell me how to check whether I have sudo command or not in my system?
Dear mgulmen,
I assume you unzipped the file. You can check the content of the current directory with the ls command.
The sudo command is available on every Linux system by default.
Dear mgulmen,
the script is in the cern_fluka_wsl-master directory.
Dear mgulmen,
what is the content of the cern_fluka_wsl-master directory?
Dear mgulmen,
then please change to that directory.
Dear mgulmen,
it did not work, because you are not in the correct directory.
Ok. I did it. Many thanks David
