It seems that something is changed, because in the past it is correctly used fff from {FlukaDir}/bin/fff path and now it tries to use fff, which is not in my PATH. All paths are correctly set in the Flair Preferences->Fluka.
there was no change in regard to fff in the latest release of FLUKA. Maybe something went wrong with the extraction, so please check if the file is present in the FLUKA directory.
Then, I would recommend adding the {FlukaDir}/bin directory to your PATH and leaving the directory settings in Flair the default (empty in case of fff).
File is present in the FLUKA directory. That was an issue with user access to the file, as the extraction was done initially on another machine. Now everything is working fine. Thank you!
