Dear Expert
How to make abbreviation and format the *.lis file not to save the zeros values of a certain column as follow
in the other words how to control the written output results
Best Regards
Fayiz
Dear Expert
Best Regards
Fayiz
Dear @mohammed.fayiz,
The *tab.lis files return the results for each energy bin, including those for which the result is zero. It is not possible to modify the format of the *tab.lis files. If you want to remove the zeros, you have to do it with your own post-processing.
Dear @amario
Many thanks for fast reply and valuable advice.
ِAccording to your valuable answer. I have got an idea to do this also through modification usxsuw. Is this easy and possible? What is the opinion?
Best Regards
Fayiz
It is possible. How easy it is, depends on your programming skills.
Many Thanks Amario for this great help
best regards
Fayez
