Dear FLUKA Experts,
I am experiencing an issue while attempting to convert usrbin outputs to rtdose using the usrbin2rtdose.py script in FLAIR. In the recent past, I was able to generate the *.dcm file by adding the usrbin2rtdose.py command in FLAIR without any issues. However, now when I try to execute the same command, be it through FLAIR or directly from the terminal, I am facing the following error:
- Processing: brain_99.dcm
Cmd: /home/project/fluka/usrbin2rtdose.py --output brain_99.dcm --usrbin brain_99.bnn --det 1
e> ERROR: executing command /home/project/fluka/usrbin2rtdose.py --output brain_99.dcm --usrbin brain_99.bnn --det 1
Error processing: brain_99.dcm
Ended: 2023.09.08 11:32:37
I am currently using a Linux system with Ubuntu 20.04 LTS installed, the latest version of FLAIR (3.2-4.5), and Python 3.8.10 is set to be the default version.
Despite researching and trying various solutions mentioned in related topics, I have been unable to resolve the issue. I wanted to reach out to you in the hope that you might be able to provide some assistance or guidance.
Thanks
