Hi,
I want to model parallel beam ( beam radius = 5 cm) of primary cosmic ray source using SPECSOUR and GCR-SPE without modeling the atmospheric layers. Then I nead to score energy-fluence spectrum of all particles starting from Z = 1 to 28 within a small spherical region placed in vacuum using USRTRACK card.
Is it possible in Fluka?
Is any input files similar to this available ?
You can run your simulation without using the GCR-SPE (and therefore the atmospheric layers) by sampling directly from the *.spc files: that would require some cautions. Note also that the *.spc files have log energy bins and the spectra range over many orders of magnitude.
The tool provided by Chris can be used to sample from the *.spc files, but you should pay attention to the high energy tail in your energy-spectra, since normally this has a non-negligible contribution. Depending on your specific application, and since you are not going to simulate the full transport through the atmosphere layers, you may need to apply a certain bias to the high-energy bins.
I will suggest to carefully read the README file included with the tool, since there are different sampling techniques you can use.
Hope that this can be a useful starting point for your simulation.
