Hello,
I run FLUKA on afs, but have very large scoring output files, which exceed my afs workspace. So I wonder if it’s possible that the output is written directly to eos, where I have much more space (,while the simulation should still run on afs!).
In case this can be done, I suppose it would be implemented in the shell script I use to submit my jobs to condor (below). I tried a few things myself but didn’t succeed.
Can you help?
Thanks,
Michael
#!/bin/bash
# Script to launch flair-FLUKA jobs on a cluster using CONDOR
# Adapted for running FLUKA with pythia events
NAME="${!#}"
RUNFILE="${NAME}.sh"
SUBFILE="${NAME}.sub"
SUBFOLD="${NAME}_fluka"
INPFILE="${NAME}.inp"
mkdir $SUBFOLD
mkdir $PWD/$SUBFOLD/output/
mv $INPFILE $SUBFOLD
# pp-events and magfld are the default needed files
# for pp collisions
ln -s $PWD/pp-events.txt $PWD/$SUBFOLD
ln -s $PWD/magfld.txt $PWD/$SUBFOLD/magfld.txt
ln -s $PWD/rd48_pion.dat $PWD/$SUBFOLD/rd48_pion.dat
ln -s $PWD/sidae.dat $PWD/$SUBFOLD/sidae.dat
ln -s $PWD/sidan.dat $PWD/$SUBFOLD/sidan.dat
ln -s $PWD/ngroupe.dat $PWD/$SUBFOLD/ngroupe.dat
ln -s $PWD/sidap.dat $PWD/$SUBFOLD/sidap.dat
ln -s $PWD/lngwei.txt $PWD/$SUBFOLD/lngwei.txt
# for every other file,
# generate the equivalent sym links
NAME=`echo ${NAME} | cut -c 1-15`
# RUNFILE
cat > ${RUNFILE} << EOF
#!/bin/bash
cd ${PWD}/${SUBFOLD}
set -x
source /cvmfs/sft.cern.ch/lcg/contrib/gcc/9.2.0/x86_64-centos7/setup.sh
export FLUPRO=$FLUPRO
export FLUFOR=$FLUFOR
EOF
# SUBFILE
# At +JobFlavour (empty)-
# change by choosing the equivalent queue
# for all job flavours, see: https://batchdocs.web.cern.ch/local/submit.html
cat > ${SUBFILE} << EOF
executable = ${PWD}/${RUNFILE}
output = ${PWD}/${SUBFOLD}/output/${NAME}.out
error = ${PWD}/${SUBFOLD}/output/${NAME}.err
log = ${PWD}/${SUBFOLD}/output/${NAME}.log
+JobFlavour = "testmatch"
queue
EOF
chmod +x $RUNFILE
condor_submit $SUBFILE
