Different DOSE by using USRBIN and comscw
I am trying to score the dose distribution of a proton in a water phantom using incident carbon ions.
I conducted two sets of experiments, using the AUXSCORE&USRBIN card for one set and COMSCW.f to score the proton dose for the other set.
For both sets of experiments, I configured the same beam information and water phantom information, and used the same seed. To my understanding, I should get the same result from the two experiments. However, the dose distribution using COMSCW.f is less than the card when I sum the dose.
截屏2023-10-30 22.41.46
The specific setup details are as follows:
In COMSCW.f, I set JTRACK .eq.1 to score the dose of the proton, while in the other card experiment, I setted what(5)=1 and what(6)=1 in AUXSCORE, which means Z and A of particles.
Can someone help me identify where I went wrong in the above-mentioned setup?
I have attached my .inp, comscw.f files, and a Python file to sum the dose distribution.
Thanks in advance!
carbon_card.inp (1.2 KB)
carbon_f.inp (1.1 KB)
comscw.f (5.3 KB)
sum.py (909 Bytes)
Hi @liweiguang,
The reason why you see such a discrepancy is because in your comscw.f, the contribution of heavy recoils originating from proton interactions is missing. In order to include them, your routine should look like the following:
	COMSCW = ONEONE
	IF (TITUSB(JSCRNG)(1:5) .EQ. "pDOSE") THEN
		IF (JTRACK.EQ.1) THEN
			COMSCW = ONEONE
		ELSEIF (JTRACK.EQ.208 .AND. J0TRCK.EQ.1) THEN
			COMSCW = ONEONE
		ELSE
			COMSCW = ZERZER
		ENDIF
	ENDIF
Where 208 represents heavy recoils, and J0TRCK is the originating particle. Details can be found in the comments about JTRACK in track.inc.
Hope this helps,
Fran
Dear Ogallar,
Your advice is correct. I followed your advice and reenacted the simulation, and obtained the same results. Thank you!
