FLUKA:4-5.2
Flair:3.5-0a
Dear FLUKA-Experts,
I am currently investigating a discrepancy between the results of the induced radioactivity calculated from FLUKA and some offline-fluence based calculations methodes. The main workflow involves the calculation of the particle fluences within the components of the irradiation station and then calculating the induced activity with ActiWiz3-Creator. These results are then compared to FLUKA RESNUCL scoring, to compare the two calculation methodes. Due to the large number of components and nuclides scored, the results were first compared based on the ratios of total induced activity:
Ratio = \frac{A_{tot, ActiWiz}}{A_{tot, FLUKA}}
During the comparison of the results, the overall agreement between the codes was quite good for most nuclides and components within the expected variance of the nuclear data and the specific methodes used for the calculation. Isomeres were a bit harder, but I do know that FLUKA handles isomeres by populating each isomeric state equally and then decaying those states, while ActiWiz uses branching ratios from nuclear data.
However for some components the Ratio between the total induced activity was quite large. Specifically for the natural Molybdenum Plate (density = ) in our irradiation setup, the ratio grew to about 1.93 for the overall induced activity. For the dominant nuclide, Mo-99, the induced activity was:
ActiWiz3: 5.91e13 Bq
FLUKA: 2.68e13 Bq
So a ratio of almost 2.2. Therefore suggesting an over/underestimation of the neutron capture within the codes. This is also reinforced by the overestimation if Tc-101 by ActiWiz compared to FLUKA:
The code for the comparison had to be a bit longer, because the RESNUCL results are printed out at 1s after irradiation and the ActiWiz results were calculated for 1h after irradiation. The decay step was done with the python package radioactivedecay. The image above shows the decay corrected data, so both results are shown after 1h of decay. Furthermore are both results scaled to the entire plate with the dimensions of 13\times24\times3\text{ cm}^3 and a density of 10.22 \frac{g}{cm^3}, since the USRTRACK scorings are based on the results with this density assigned to the Molybdenum.
I know that FLUKA by default uses 10.22 \frac{g}{cm^3} for the density of Molybdenum, while ActiWiz uses 10.28 \frac{g}{cm^3}.
Due to this discrepency I tried to manually calculate the expected activity based on the available data and the particle fluences calculated with FLUKA. The particle fluences (attached below) are postprocessed to yield particles/s/\text{cm}^2.
Within FLUKA I use the JEFF-3.3 pointwise library, and ActiWiz was also build on the JEFF-3.3 data (and EAF and ENDFB/VIII0), as far as I know. The dominant production pathways for Mo-99 should be the neutron capture of the stable Mo-isotopes and the (n,2n)-reaction of Mo-100. The (\gamma/n)-reaction only has neglectable contributions within our setup (<0.00086%). Therefore I wrote small code solving the matrix exponential for the Bateman-equations only considering the Mo-92 to Mo-100. The effective cross sections for the transition matrix were calculated with the rebinned neutron fluence taken from the FLUKA USRTRACK scoring and then folded with the 709 Groups CCFE JEFF-3.3 data. Additionally I calculated the same for the other libraries JEFF-3.2, JEFF-4.0 (1102 Groups CCFE) and EAF. Furthermore I did the same with JEFF-3.3 pointwise data and linear interpolation between the energies, but I would say this is the one I am least confident with. I also got a license for FISPACT, which should be a more complex version of my groupwise matrix exponential calculations, to check, if I missed something:
Manually (JEFF-3.3 709 CCFE): 5.65e13
Manually (JEFF-3.3 Pointwise): 4.9e13
Manually (JEFF-3.2 709 CCFE): 5.40e13
Manually (EAF2010): 5.78e13
Manually (JEFF-4.0 1102 CCEF): 5.21e13
Manually (ENDFB/VIII.0 709 CCFE): 5.24e13
FISPACT (JEFF-3.3 709 CCFE): 5.72e13
All these calculations rather agree with ActiWiz3 than with FLUKA. I also checked the production contribution by energy within ActiWiz and most of the production happens below 20 MeV and predominantly by neutrons.
So FLUKA should be using data from JEFF-3.3, just as ActiWiz does and should not be based on the FLUKA models used above 20 MeV. The manual calculations above suggest, even though i wouldn’t entirely bet on them, that the discrepancy is also not entirely based on the pointwise vs groupwise data.
My question would be, if there is any idea on what else might be the cause for this disparity?
Thank you in advance!
Flux_NEUTRON_MoPlate.txt (51.8 KB)
Flux_PROTON_MoPlate.txt (51.8 KB)
Flux_PHOTON_MoPlate.txt (51.8 KB)
99MoBestV12.flair (280.8 KB)
99MoBestv12.inp (107.9 KB)
