Discrepancy in Energy Deposition Results Between MGDRAW and USRBIN
I am running a simulation with 1000 primary electrons interacting in a 1×1×1 cm³ water cube as a simple example to understand the differences in energy deposition calculations in the TARGET region.
I am using two methods to determine the energy deposition:
MGDRAW.F:
My customized MGDRAW routine logs energy deposition events to a file (1_Energy_Deposition_TARGET.dat). By summing the RULL values (which represent the energy deposited at each event), I obtain a total energy deposition of approximately 0.07116 GeV. This corresponds to about 7.116×10⁻⁵ GeV deposited per electron.
USRBIN scoring:
I also scored energy deposition in the TARGET region using the USRBIN card. The resulting output file (3_Target.dat) reports an energy deposition of about 0.00188348 GeV per electron.
I expected both methods to yield the same total energy deposition, but they differ significantly.
Could you please help me understand the origin of this discrepancy?
For your review, I have attached the following files:
MGDRAW routine:
mgdraw_dump.f (17.3 KB)
1_Energy_Deposition_TARGET.dat (57.0 KB)
USRBIN output: 3_Target.dat
3_Target.dat (29 Bytes)
exampl.flair (3.3 KB)
exampl.inp (1.5 KB)
Thank you in advance for your assistance.
Zohrab
The RULL values of the ENDRAW entry of mgdraw.f account only for point-like energy deposition events. Energy deposition along charged particle tracks is stored in the DTRACK array available in the first part of the routine.
Thank you very much for the helpful information.
Thanks and regards
Zohrab
