I am trying to score the activation products in different times, based on the activation exercise from the latest beginner course. As I added more sampling times using the DCYTIMES card, I have noticed an anomaly in the processed files.
I defined 3 decay times: 1 hour, 2 hours, and 3 hours after the end of the irradiation period,
and created matching RESNUCLEI cards for each time - ActT-1h, ActT-2h and ActT-3h, respectively. If I understand correctly, the times’ order goes by the order in the DCYTIMES card, so time #1 is the 1 hour, #2 is 2 hours, etc.
In order to make sure the scoring was set correctly, I looked at the .inp and .out files created after the run. As far as I can see, everything is set according to the pre-described logic. But when I look at the processed sum.lis file, I see that the ActT-1h detector is set for 2 hours, ActT-2h for 3 hours, and no time was set to ActT-3h.
What am I missing here? Which times were set for each detector?
Please find my attached files.
Thank you kindly in advance,
Hen Shukrun
rp-calculations_24_sum.lis (46.5 KB)
rp-calculations-exercise_full_exercise.flair (7.4 KB)
rp-calculations-exercise_full_exercise.inp (3.2 KB)
