DPA calculation for Si
I am a new user and want to use fluka to calculate dpa. I am trying to reproduce results from several literatures for exercise. But the results of dpa calculated by me are all 1/2 lower than that in the literatures.
The first dpa calculations that I tried to reproduce is the blue line of Fig. 2(d) in paper
2014 Simulation of beam induced lattice defects of diamond detectors using FLUKA.pdf (688.0 KB)
. This case is the proton irradiating silicon of size 1x1x0.04 cm^3. My input file is
Si_Guthoff2014.inp (1.4 KB)
Despite your intentions, actually you did not upload the relevant files, in particular your input file.
this is the file pls have look at that thanks for your time
Dear Tausif,
two observations concerning your input file:
  • when using DPA, ion transport should be switched on via the IONTRANS card. The energy threshold of heavy ions shall also be set to a low value (e.g., 1 keV) with PART-THRES (setting 4-HELIUM transport to 1 keV, which applies to heavy ions in general).
  • to reproduce the results of the paper, you can use the DPA-NRT card, introduced in FLUKA 4-3.0 as a replacement to the deprecated DPA-NRES : Release of FLUKA 4-3.0 | The official CERN FLUKA website (note that the same FLUKA release has introduced the arc-DPA quantity)
Giuseppe
