The pulse amplitude spectrum was calculated about lithium 6 chamber, the result is:
the magnitude on the first channel is especially large, what induced this?
it seems the magnitude on the first channel is normal by Mcnp6, here is the result:
Dear @Newconcept_1979,
if you are using the DETECT scoring with zero minimum energy, then all events where no energy is deposited in the detector is still added to the first bin.
You can avoid this, by
@horvathd , thanks for your reply!
