Dear Fluka experts,
I hope you could help me with my issue. I’m working on a theoretical model to predict the signal output for a given scintillator designed for x-ray imaging. I need to account the contribution to scintillation light given specifically only by fluorescence photons. The trouble is to exclude the contribution by the primary particles, which are also photons. To do so, I decided to first calculate energy deposition, trying with the option ENDRAW of the routine mgdraw. Using a IF condition my idea was to select only photons having energy lower with respect to the primary beam photons. That is the code:
ENTRY ENDRAW ( ICODE, MREG, RULL, XSCO, YSCO, ZSCO )
LFCOPE = .TRUE.
OPEN ( UNIT = 60, FILE = “energyfluo.txt”, STATUS = ‘UNKNOWN’)
IF(MREG.EQ.4 )THEN !region "4" is the scintillator region
IF(JTRACK.EQ.7) THEN
IF(PMOFLK(7).LT. PBEAM) THEN
WRITE(60,*) SNGL(RULL)
END IF
END IF
END IF
The fact is that I’m not sure about the variables I used to select energy (since dealing with photons I decided to select fluorescence photons with a condition on momentum), as well as I don’t understand why I get an empty file when IF(JTRACK.EQ.7) condition is activated (when not acivated results seems to be anyway meaningless).
(another question is about EMFFLUO: setting fluorescence “on” or “ignored” I get the same number of optical photns output, while setting “off” I get a very reduced output…so it is not clear to me what is intended with options “off” or “ignored”…)
Thank you in advance for any precious help!
Riccardo
