I hope you are all well. I am trying to represent the spectrum of all the single energy depositions provoked by any particle (primary or secondary) in a region of interest (called in the routine “region-int”).
For that matter, I tried to use the USERDUMP card in FLUKA with the mgdraw.f subroutine. I just wanted to check that I am indeed storing all such depositions through the routine I am using (please find it attached).
As far as I am concerned, there are two types of energy deposition I can score with mgdraw.f:
Those given by DTRACK in the MGDRAW entry of the subroutine.
Those given by RULL in the ENDRAW entry of the subroutine.
Are there any other I should add, even if that requires the use of another card or routine?
I also wanted to confirm if the results were in GeV, as every energy output in FLUKA.
Thank you very much for your reply, it is really helpful! I apologise for the wrong region name, I changed it here for the sake of clarity in the subroutine (region-int(erest)).
