Error 12 running problems
Dear fluka experts,
I’m trying to run an input with a cell receiving a proton beam, but I’m getting the error 12:
Error: No rancelula_01002 generated!
Error: No celula_01001.err generated!
The input is also not generating an .err file, I can’t know exactly where I’m going wrong… can you help me?
I couldn’t send it as an attachment, but it follows in text:
TITLE
celula
*Set the defaults for precision simulations
DEFAULTS PRECISIO
*Define the beam characteristics
BEAM -0.01 0.8 0.8 PROTON
*Define the beam position
BEAMPOS 0.0 0.0 -0.00031
GEOBEGIN COMBNAME
0 0
*Black body
SPH blkbody 0.0 0.0 0.0 1
*Void sphere
SPH void 0.0 0.0 0.0 0.001
SPH cito 0.0 0.0 0.0 0.0003
SPH nucleo 0.0 0.0 0.0 0.00015
END
*Black hole
BLKBODY 5 +blkbody -void
*Void around
VOID 5 +void -cito
*Target
CITO 5 +cito -nucleo
NUCLEO 5 +nucleo
END
GEOEND
MATERIAL 1 nucleo
MATERIAL 1 cito
MATERIAL 15 30.97 1.823 30phos
MATERIAL 16 32.07 1.960 32sulf
MATERIAL 17 35.45 0.0032 35clo
MATERIAL 19 39.10 0.856 39pot
COMPOUND -0.106 HYDROGEN -0.742 OXYGEN -0.09 CARBONnucleo
COMPOUND -0.032 NITROGEN -0.026 phos -0.004 sulfnucleo
COMPOUND -0.1055 HYDROGEN -0.563 OXYGEN -0.2988 CARBONcito
COMPOUND -0.0251 NITROGEN -0.0004 phos -0.0011 SODIUMcito
COMPOUND -0.0024 sulf -0.0016 clo -0.0021 potcito
*..+…1…+…2…+…3…+…4…+…5…+…6…+…7..
ASSIGNMA BLCKHOLE BLKBODY BLKBODY
ASSIGNMA VACUUM VOID VOID
ASSIGNMA cito CITO CITO
ASSIGNMA nucleo NUCLEO NUCLEO
USRBDX 101 PROTON 21 NUCLEO CITO fluxo
USRBDX 0.0001 0.0 1000 &
USRBIN 10 PROTON -22 0.000015 0.000015 0.00015proton
USRBIN -0.000015 -0.000015 -0.000015 100 100 100 &
*Set the random number seed
RANDOMIZ 1.0
*Set the number of primary histories to be simulated in the run
START 100
STOP
flair project file
Version: 300
Mode: fluka
Title: celula
md5: 718f5e691918b958ea5f9b0e3338deba
Input:
TITLE
celula
DEFAULTS PRECISIO
BEAM PROTON -0.01, 0.8 0.8
BEAMPOS , 0.0 0.0 -0.00031
GEOBEGIN COMBNAME
*Black body
*Void sphere
END
*Black hole
REGION BLKBODY 5
+blkbody -void
*Void around
REGION VOID 5
+void -cito
*Target
REGION CITO 5
+cito -nucleo
REGION NUCLEO 5
+nucleo
@select=1
END
GEOEND
MATERIAL nucleo, 1
MATERIAL cito, 1
MATERIAL phos 15 30.97 1.823, 30
MATERIAL sulf 16 32.07 1.960, 32
MATERIAL clo 17 35.45 0.0032, 35
MATERIAL pot 19 39.10 0.856, 39
COMPOUND nucleo -0.106 HYDROGEN -0.742 OXYGEN -0.09 CARBON -0.032 NITROGEN -0.026
phos -0.004 sulf
COMPOUND cito -0.1055 HYDROGEN -0.563 OXYGEN -0.2988 CARBON -0.0251 NITROGEN -0.0004
phos -0.0011 SODIUM -0.0024 sulf -0.0016 clo -0.0021 pot
ASSIGNMA , BLCKHOLE BLKBODY BLKBODY
ASSIGNMA , VACUUM VOID VOID
ASSIGNMA , cito CITO CITO
ASSIGNMA , nucleo NUCLEO NUCLEO
USRBDX fluxo 101 PROTON 21 NUCLEO CITO, 0.0001 0.0 1000
USRBIN proton 10 PROTON -22 0.000015 0.000015 0.00015 -0.000015 -0.000015 -0.000015
100 100 100
RANDOMIZ , 1.0
START , 100
STOP
EndInput
Page: Output
Run information
Run:
Status: 4
queue: *Default
End
Run: celula_01
Rnd: 1
Last: 2
Status: 4
StartRun: 1678196413
Parent:
queue: *Default
End
Geometry: Geometry
Layer: Detector
Palette: 1
Palette._visible: 1
End
End
Plots information
Plot: Red
Type: Geometry
basisu: -0.707107 0.707107 0
basisv: 0 0 1
extends: 0.0007981173430384113 0.0003587206108602245
layer: Media
origin: 1.69558e-05 -1.744e-05 -2.98144e-05
End
Plot: Green
Type: Geometry
basisu: 0.836516 0.0173376 0.547668
basisv: 0.224144 0.901221 -0.370891
extends: 1.25e-09 1.25e-09
layer: 3D
origin: -6.72058e-09 -1.65884e-07 9.12929e-08
End
Plot: Blue
Type: Geometry
basisu: 0 -1 0
basisv: 0 0 -1
coord: Y-Z
extends: 10079.827937451486 4530.464181273321
layer: Media
origin: 0 7.95459 -37.364
End
Plot: Magenta
Type: Geometry
coord: X-Y
extends: 100.0 44.94584837545126
layer: Media
End
Thank you so much in advance!!
Please look at 001.log file. In case you do not manage to debug from it, please upload your files by means of the dedicated button (upward arrow).
Hi, now it’s attached, thank you!!
celula.inp (2.2 KB)
celula.flair (2.4 KB)
practice_4_Th_geometry001.log (96 Bytes)
celula_01001.out (31.0 KB)
The .out file ends with the relevant error message:
  **** Low energy neutron xsec not found for some media            5           9  ****
 phos
 sulf
 clo
 pot
In the respective elemental MATERIAL definition [by the way: do not fill the Am field, as prescribed in the manual, nor fill the A field, since you do not want a (radioactive!) mono-isotopic composition], you should give a case sensitive name matching the one in the low energy neutron library (e.g., PHOSPHO, and not phos).
Otherwise, you could ask for the new point-wise treatment instead (by means of an empty LOW-PWXS card), requiring to download the respective libraries.
Hello, thank you for the reply. I fixed your considerations and now I’m getting the following error:
e> line 0: color axis has cb coord of -1; must be above 0 for log scale!
e> ERROR: Gnuplot errors or warnings found
what it means? what exactly do I need to change in the input?
celula.flair (2.6 KB)
celula.inp (2.2 KB)
celula_01.out (1.0 KB)
This is an error message from gnuplot.
It means that you are trying to plot in logarithmic scale something that is “-1”.
Try to do the plot in linear scale
