Error code 2 ...?
Hello Fluka community
I have an error when trying to the attached flair file.
I run with the latest version of flair and Fluka.
It starts ok, but stop after a few minutes, with that kind of message in the .out file : pt:
(there is no .err file but a /core is present)
CYB.flair (41.7 KB)
Ecut = 6.1100E-01 MeV, Pcut = 3.3333E-02 MeV
BIAS = F, Ray. = T, S(q,Z) = T, Pz(q,Z) = T, Acolin.= F
Delayed:
181 STRpl4 2 PORTLAND 27 PORTLAND
Prompt:
CAL091-IRSD-cyberknife.inp (47.5 KB)
Delayed:
182 Sable 19 Sand 51 Sand
Prompt:
Delayed:
Successfully allocated 406042944 bytes of memory
Successfully allocated 446042944 bytes of memory
Successfully allocated 486042944 bytes of memory
Successfully allocated 526042944 bytes of memory
Successfully allocated 652960784 bytes of memory "
I thought it was the EMF-CUT, transport and/or PROD-CUT but changing or disable it, doesn’t change anything.
I’m trying to transport 6 MeV photons in different directions (tir6 in the example file), throughout
my building geometry
Thanks for your help
Hugues
Hello
I reply to myself :wink: ah ,ah !
I finally redo the input file without the #define, running each case separatly, defining
different BEAMPOS for each case, in 3 different flair files, without any running problems.
Then I tried to redo the #define manually with the #else if at the top of the input window.
It is working now
It has smthg to do with the copy paste in the main input window, I guess
but it is working now,
Hugues
